NEW VERSION OF SOUTHERN LIGHTS!
Josh (SNIP)
- A Forum Addict
In this version it looks totaly different! the new style is way better and cool! You can also choose from over 20 preloaded styles that you want the song to be in and you can create your own patterns and the program will save them for you for next time you open it! Download it here! - http://www.winmxunlimited.net/programs/sl/
Looking for Fast Winmx help?, MXTools, Visual Basic Help,Cool programs? Well visit http://www.winmxunlimited.net
- p2p-sharing-rules
- Moderator
- p2p-sharing-rules
- Moderator
It doesn't display the WinMX chatroom list in Southern Lights it just displays the chatrooms you're in only.
- p2p-sharing-rules
- Moderator
if your using v1.0.5 did you try the refresh list button? If you're not in any rooms when you start it up or if you join a new room you have to refresh the list.
- p2p-sharing-rules
- Moderator
That could the reason why, i'm not sure.
Do you have southern lights on the same drive as WinMX?
I'm not sure why it's not working right for you.Sorry I can't help you.
Maybe you can ask Josh at his forum or maybe he'll reply here to try to help you.
yes it's in the same dir. as winmx(same drive/same partition)
again i've had this moreoften with similar looking progs(guess they all came from josh..not sure)
thnx anywayz for your effort m8
i've always just stopped testing bcause i use different progs but i donot want to hand those out to rooomiezz...this and some others would have been nize for them to play
thnx again... you tried that's what counts
- p2p-sharing-rules
- Moderator
- p2p-sharing-rules
- Moderator
http://www.winmxunlimited.net/ Weird I've no problem getting Josh's site.
- p2p-sharing-rules
- Moderator
