New BitComet Version Released
p2p-sharing-rules
BitComet v0.94 Oct. 9 , 2007
What's new
GUI Improved: new function in context menu of BT task file list: search ED2K link for selected file
GUI Improved: enable Windows open file security warning for downloaded executable files
GUI Improved: new option in preferences dialog: Login BitComet Passport Automatically
GUI Improved: hide notify window of start downloading torrent file immediately after download finished
GUI Improved: support query file size and server resume-supported ability for BC link in HTTP task properties dialog
GUI Improved: lanuch BitComet resource browser to capture video file when click "download video" in IE context menu
GUI Improved: add Accelerate Keys page to Help menu
GUI Improved: remove horizontal scroll-bar of fav list and task info pane list
GUI Bugfix: tasks in queue will not start automatically at next time of BitComet launch
GUI Bugfix: task list and file list do not refresh after rename task
GUI Bugfix: get invaild BC link when copy BC link from FTP task
GUI Bugfix: the display effect of resizing floating window is not correct under Windows Vista
GUI Bugfix: zero-size BT task will display in downloading list all the time
Core Improved: eMule plugin supports searching ED2K link for selected file of BT task, to help BitComet download from ED network
Core Improved: new toolbar button in BitComet resource browser to capture flv video files in webpage and download them
Core Improved: HTTP task decrease download rate automatically when disk writing speed much lower than downloading rate
Core Bugfix: HTTP task will download file repeatedly in some special situation of hash check failure
Core Bugfix: the file name and sub-directory name in torrent file is invaild when make torrent of an entire disk from root directory
Core Bugfix: in-queue task number may get wrong if select to download remainder files of a BT task after part files of which download finished
Core Bugfix: eMule plugin window appears incorrectlly sometimes
Core Bugfix: preview download mode does not work correctly sometimes
Core Bugfix: play button does not display in task list after download video file from HTTP server without resume-supported ability
Download links:
BitComet 0.94.exe
BitComet 0.94.zip
BitComet 0.94 plugin.exe
p2p-sharing-rules
BitComet v0.95 Nov.05 2007
What's new
GUI Improved: new hotkey Ctrl+B for HTTP/FTP batch download
GUI Improved: remove search bar below favorites list
GUI Improved: remove recommend window
GUI Improved: if download rate in user list of BT task less than 1K, display it as "<1 kB/s"
GUI Improved: display "play" button in task list for flv and swf file when it download finished
GUI Improved: hot key Ctrl+R in add download group dialog will fill max value of wildcard automatically
GUI Bugfix: icons in task log display incorrectly in Windows Vista
GUI Bugfix: task auto stop function can not work if this task has been previewed
GUI Bugfix: Scheduler will not refresh task list after pause all task
GUI Bugfix: user name and password info is not imported from captured FTP URL link
GUI Bugfix: the option of search for more users to speed up download in HTTP task properties dialog does not work
Core Bugfix: .bc! file is not removed occasionally when download very small HTTP files
Core Bugfix: unable to download zero byte HTTP file
Core Improved: improve preview download mode of BT task, decrease CPU usage
Core Improved: eMule plugin can handle ED2K link opened from IE
Core Improved: when BitComet creates task in eMule plugin, the task category of new task will be set to _bitcomet_imported
Core Improved: when BitComet downloads BT task from eMule plugin, if the same file already exists in plugin's download queue, downloaded data will be imported
Core Bugfix: private torrent didn't disable persistent seeding
Download links:
BitComet v0.95 setup.exe
BitComet v0.95.zip
BitComet v0.95 plugin.exe
p2p-sharing-rules
BitComet v0.96 Nov.07, 2007
What's new:
GUI Bugfix: bugs in install pachage script
Core Bugfix: cannot query file size of FTP link containing non-english character in FTP task properties dialog
Core Bugfix: HTTP connection logs do not display in version 0.95
Core Improved: main program compressed, decrease loading time
Download links:
BitComet 0.96 setup.exe
BitComet 0.96 plugin.exe
BitComet 0.96.zip
p2p-sharing-rules
BitComet 0.97 Dec 07, 2007
What's New
GUI Improved: improve BC link support when download all links from web page
GUI Improved: add overwrite prompt when save torrent file of a BT task to another location
GUI Improved: new command in Tools menu: Show eMule plugin
GUI Bugfix: after sort URL list in download all links dialog, the downloaded links do not match the selected links
GUI Bugfix: torrent file association icon cannot display
GUI Bugfix: install package compatible with Windows Vista
GUI Bugfix: invaild input prompt for save location in BT/HTTP task properties dialog
GUI Bugfix: status bar language not changed after switch UI language
Core Bugfix: program may crash when download HTTP file from redirected server
Core Bugfix: task added at eMule plugin startup will not be created successfully
Core Bugfix: cannot connect to certain tracker that forbid web browser connection
Core Bugfix: v0.96 cannot load configuration file bitcomet.xml in Windows Vista/2K
Download links:
BitComet 0.97 setup.exe
BitComet 0.97 plugin.exe
BitComet 0.97.zip
p2p-sharing-rules
Here's the newest BitComet version for 2008.
v0.98 was release on Jan 10 2008.
What's new:
GUI Improved: start downloading torrent file while show the task properties dialog of new opened BC link
GUI Improved: search box in toolbar remains in the same row of the toolbar buttons when resize main window
GUI Improved: HTTP task properties dialog support query file size and server resume-supported ability for HTTP/FTP link with password authentication
GUI Improved: improve display effect of peer download statusbar in BT task peer list
GUI Improved: BT task peer list support sorting
GUI Improved: BT task peer list display download statusbar of each peer
GUI Improved: HTTP task connection list display download statusbar of each source
GUI Improved: new command in HTTP task context menu: Verify MD5 checksum
GUI Bugfix: ESC key donot work in download all links dialog
GUI Bugfix: task remains in queue after deleted into recycle bin
Core Improved: improve HTTP task download algorithm to avoid download speed decrease near finish
Core Improved: HTTP task support redirect to FTP url
Core Bugfix: preview unfinished HTTP task may cause program crash
Core Bugfix: tasks which disable Long-Time Seeding download should not upload for Long-Time Seeding
Core Bugfix: tasks in recycle bin should not upload for Long-Time Seeding(persistent seeding)
Anyways here's the download links
BitComet 0.98 setup.exe
BitComet 0.98 plugin.exe
BitComet 0.98.zip
p2p-sharing-rules
BitComet v0.99 Feb.1 2008
Release Notes
GUI Bugfix: Failed to verify login password at BitComet startup will lead to crash
GUI Improved: check software update in system automatically, can be enable in option dialog
GUI Improved: new FireFox extension, support download file using BitComet
GUI Improved: new option in advanced setting page: query task comment and snapshot info automatically
GUI Improved: when browse the save location folder of task, do not open new window if this folder has already been opened
GUI Improved: add time interval setting to context menu of floating window
GUI Bugfix: BC link of BT task displayed as error link in HTTP task properties dialog
Core Improved: increase connection speed of downloading torrent file in BC link, and querying HTTP file size
Core Bugfix: preview in full screen mode for more than twice do not work properly under Windows Vista
Download links
BitComet 0.99 setup.exe
BitComet 0.99 plugin.exe
BitComet 0.99.zip
p2p-sharing-rules
BitComet 1.00 Mar 27, 2008
What's New
GUI Improved: move "add torrent to my sharing" check box in BT task properties dialog to Advanced page
GUI Improved: new command in Tools menu: check software update
GUI Improved: new command in context menu of Peer list: Remove peer
GUI Improved: new command in context menu of Tracker list: Remove tracker
GUI Improved: FireFox extension add download video files command to Tools menu, which can capture video files in webpage.
GUI Bugfix: puase and resume preview video file will lead to exit full-screen mode
GUI Bugfix: Refresh button in toolbar of BitComet resource browser does not work
Core Improved: update TCP half open limit modification for Windows Vista
Core Bugfix: Long-Time Seeding does not stop when Scheduler pause all download
Core Bugfix: BitComet resource browser cannot download video files embedded in webpage after install IE7
Download links
BitComet 1.00 setup.exe
BitComet 1.00.zip
BitComet 1.00 plugin.exe
p2p-sharing-rules
BitComet v1.01 May 5, 2008
GUI Improved: new option in advanced connection settings of preferences dialog: Enable Anti-Leech
GUI Improved: FireFox extension add download video files command to context menu of web page
Core Improved: after enable Anti-Leech, connections which transfer little data during a long time will be disconnected
Core Improved: enhance video file preview, support avi, rmvb, wmv, mpg, flv, ogm, mkv, mp4 files
Download links
BitComet v1.01.exe
BitComet v1.01.zip
BitComet v1.01 plugin.exe
Thanks for the update P2P :D
p2p-sharing-rules
BitComet v1.02 June 3 2008
What's new
GUI Improved: task category will display "empty" when not set
GUI Improved: whether to search for mirrors when add new HTTP task can be set as default setting
GUI Improved: new option for preview window: keep aspect ratio of video
GUI Improved: new switch button in toolbar of preview window: skip undownloaded range or waiting for buffering
GUI Improved: BitComet resource browser (CometBrowser.exe) will exit immediately after close all its window
GUI Improved: removw server mode option in advanced netword settings
GUI Bugfix: user name and password in HTTP/FTP task properties dialog do not take effect
Core Improved: Long-Time Seeding can download file boundary data for BT task, where one piece containing multi files
Core Improved: when select part files of a BT task to download, the file boundary data will be saved in taskname.piece_part.bc!
Core Improved: enhance virus protect auto-config
Core Improved: support TCP half-open patch for Windows XP SP3
Core Improved: FireFox extension support FireFox 3.0
Core Bugfix: error occurs when connect to certain trackers: "Tracker Reture Zero Length Response"
Core Bugfix: EVENT_COMPLETE should be sent to tacker only when all files in BT task downloaded, not only selected
Core Bugfix: HTTP download task do not reconnect server after connection disconnected by server
Core Bugfix: HTTP download task do not drop invalid data from out-of-date mirror server, lead to redownload after hash check failure
Download links
BitComet 1.02 setup.exe
BitComet 1.02.zip
BitComet 1.02 plugin.exe
p2p-sharing-rules
Here's July's update for BitComet.
BitComet v1.03 July, 17 2008
What's new:
GUI Improved: redesign preferences dialog, improve option layout
GUI Improved: new advanced option: User-agent sent to HTTP tracker
GUI Improved: new advanced option to adjust Anti-Leech rules
GUI Improved: new advanced option to config file path of video player
GUI Improved: improve connection number display in task list for HTTP/FTP task
GUI Improved: add left size column to task list (hidden by default)
GUI Improved: add context menu to BT task peer list header, to select columns to display
GUI Improved: BT task peer list support group display
GUI Improved: freeze BT task peer list when ScrollLock turned on
GUI Improved: HTTP task properties dialog will display free disk space of save location
GUI Improved: BitComet not responding dialog can be disabled
GUI Improved: BitComet don't hide already running emule plugin window when startup
GUI Improved: remove task category management
GUI Improved: remove history task list
GUI Improved: remove video file preview window, launch external video player instead
GUI Improved: remove BitComet resource browser from install package
GUI Bugfix: FireFox extension can download flv file from FireFox cache
Core Improved: remove NAT Traversal via UDP, to improve TCP transfer efficiency
Core Improved: improve TCP half-open patch for Windows XP SP3
Core Bugfix: after a file in BT task download finished, disconnect corresponding Long-Time Seeding connection immediately
Core Bugfix: the pieces containing file boundary data of BT task will be download repeatedly in some situation
Core Bugfix: BitComet does not save the BT tasks created by BC link when program exit
Download links:
BitComet v1.03.exe
BitComet v1.03.zip
BitComet v1.03 plugin.exe
p2p-sharing-rules
BitComet v1.0 Aug 22, 2008
Changelog
GUI Improved: "my shared torrent list" turns into "torrent archive". all downloaded torrent files will be saved there.
GUI Improved: add filter edit box to torrent archive list.
GUI Improved: remove deleted task list. when delete BT task, its torrent file can be kept in torrent archive
GUI Improved: new option: clear peer sharing torrent list when program exits. enabled by default.
GUI Improved: new option: standby, hibernate, restart or shutdown computer when all task downloaded and stopped
GUI Improved: new command in Tools menu: check for BitComet updates
GUI Improved: improve Long-Time Seeding download rate display in peer list
GUI Improved: displays play button in task list after download audio file, like mp3, wma
GUI Bugfix: open file from file list will fail, after rename BT task and restart BitComet
GUI Bugfix: when make torrent file in v1.03, files in sub-directories will not be added into torrent
GUI Bugfix: when main window is not wide enough, the search box in toolbar will display in invalid position
GUI Bugfix: total downloaded/uploaded bytes in statistics list will be clear in some situation since v1.02
Core Improved: all opened torrent files will be saved to archive folder
Download links
BitComet v1.04 setup.exe
BitComet v1.04.zip
BitComet v1.04 plugin.exe
p2p-sharing-rules
BitComet 1.05
Oct.10, 2008
What's new:
GUI Improved: split save location of BT task into 2 parts: save path and filename for single-file task, save path and subfolder for multi-files task.
GUI Improved: when add new BT task, start now/start later combo box changes to 2 buttons below in the dialog
GUI Improved: remove "set as default" button in BT and HTTP/FTP task properties dialog. Save path of new task will be added into candidate directory list in option dialog automatically.
GUI Improved: new candidate directory list in option dialog. The directories in list can be pick up easily when add new task.
GUI Improved: rewrite batch HTTP/FTP download dialog and download all dialog. They are merged into a new designed batch download dialog, which is more convenient.
GUI Improved: new site password manager for HTTP/FTP download. Username & password will be filled automatically when add new task if existed. This can be enabled in option dialog.
GUI Improved: in torrent maker dialog, network type combo list changes into private torrent check box and add DHT nodes check box.
GUI Improved: after popular software update checking, updated softwares will be list under tools menu in main window.
GUI Improved: show an error message box when click [play] on a finished task, while the downloaded file has been deleted.
GUI Bugfix: under Windows Vista, search box in toolbar displays incorrectly after switch search type
Core Improved: UI language files change from .xml format to .mo format, which are more universal and can be concurrent translated in https://translations.launchpad.net/bitcomet
Core Bugfix: under Windows Vista, BitComet will lost task list if running under administrator privilege
Core Bugfix: if the HTTP task stopped because the file locked by other program, data integrality can not be guaranteed when resume downloading.
Core Bugfix: in few situations, the BT task finish progress is 100% after hash checking, but the file finish progresses are not displayed as 100%
Core Bugfix: if a BT task has been specified file download order, program will lose respond when switch a file to be download or not.
Download links
BitComet 1.05 setup.exe
BitComet 1.05.zip
BitComet 1.05 plugin.exe
p2p-sharing-rules
I missed Nov. update too so I added the changelog & download links for it to this post.
Changelog
v1.06 Nov. 12 2008.
GUI Improved: rearrange main menu, "tools" changes to "software", "options" changes to "tools"
GUI Improved: add submenu to select default save directory in tools menu
GUI Improved: improve directory setting panel in option dialog. double click to set default save directory
GUI Improved: new Web Interface setting panel in option dialog
GUI Improved: add MD5 verify pane to HTTP/FTP task properties dialog
GUI Improved: downloaded files can be moved to candidate directory from context menu of task list
GUI Improved: add downloaded size and uploaded size columns in task list (hidden by default)
GUI Improved: remove Flv player from install package
GUI Improved: improve Long-Time seeding display in peer list
GUI Bugfix: fix some translation errors.
Core Improved: new Web Interface modular, to remote BitComet from web browser (disabled by default)
Core Improved: improve Long-Time Seeding module
Core Improved: increase first-time loading speed of torrent share list
Core Improved: limit download rate for HTTP task automatically when download speeding larger than disk writing speed, to avoid wasting too many memory for disk cache
Core Improved: update eMule plugin to v0.49b
Core Bugfix: UI may response slowly when downloading BT task in high speed
Core Bugfix: program crash after install IE8 beta
v1.07 Dec. 3 2008
GUI Improved: add tags to task by context menu (support multi-selection)
GUI Improved: filter tasks by tag from favorites list
GUI Improved: new option in task setting panel of option dialog: add tag to new task by download file type
GUI Improved: display task tags and public date for BT task in summary pane
GUI Improved: display task tags for HTTP task in summary pane
GUI Improved: add "Apply" button to option dialog
GUI Improved: new option in Web Interface setting panel of option dialog: display prompt window for web interface operation
GUI Improved: show prompt window when open a torrent file that already existed in torrent archive list
GUI Improved: when modify the save path of an existed BT/HTTP task, show a prompt to choose whether to move downloaded files to new save path
GUI Improved: when modify BT/HTTP task save path, show the path auto-complete drop list
GUI Improved: when the width of file list in BT task properties dialog is not enough for file name, try to display the head and tail part of the filename, with the middle part as ellipsis
GUI Improved: when switch task lists, task tags or torrent share list from favorites list, remember the scroll bar position and task selections before switch
GUI Improved: add context menu to BitComet passport and DHT area in main status bar
GUI Improved: when click comment or snapshot icon in task list, display them below task list, instead of open a browser window
GUI Improved: add support for 10 new languages
GUI Bugfix: program crash when display task delete confirm dialog under Win98/2K
Core Improved: Web Interface support create new task from BC link
Core Improved: When create a task that already existed, Web Interface will displays an webpage link to the existed task
Core Improved: eMule plugin can download file boundary data for BT task, where one piece containing multi files
Core Improved: create bak file when save task list to downloads.xml
Core Bugfix: error data received in file boundary piece makes task download can not finish
Download links
BitComet 1.06.exe
BitComet 1.06.zip
BitComet 1.06 plugin.exe
BitComet 1.07.exe
BitComet 1.07.zip
BitComet 1.07 plugin.exe
p2p-sharing-rules
v1.09 2009.01.20
Core Bugfix: certain BT task may occur progress error caused by saving file boundary data when task stop
v1.08 2009.01.18
GUI Improved: add filter by file type to file list in BT task properties dialog
GUI Improved: display torrent create software and create date display BT task properties dialog
GUI Improved: support to add mirror URL manually in HTTP task properties dialog
GUI Improved: move the option of "power off or standby after download finish" from option dialog to Tools menu
GUI Improved: remove toolkit VistaTcpPatch.exe, merged into main program
GUI Improved: open torrent file directly if existed in torrent archive when open BC link
GUI Improved: show task archive and torrent collection immediately after program startup, without pending load
GUI Improved: improve the item number info in status bar when filter the torrent archive and torrent collection
GUI Improved: append new torrent to the bottom of torrent archive or torrent collection list
GUI Improved: remove old torrent from the top of torrent collection list, when the torrent number reaches the max number
GUI Improved: new download status icon in torrent archive list, to indicate the task download finished
GUI Improved: add "open save folder" command to the context menu of torrent archive list, available after task download finished
GUI Improved: add "Unhide all" command to the context menu of torrent collection list
GUI Improved: hit Del to delete selected items in torrent archive list, or block selected items in torrent collection list
GUI Bugfix: when the item in torrent archive or torrent collection has no snapshot, click the empty snapshot icon area will open invalid webpage
Core Improve: improve connection algorithm for Long-Time seeding
Core Improve: improve file boundary data dave for BT task
Core Improve: ignore thumbs.db when makiing torrent file
Core Bugfix: download failed from certain video website
Core Bugfix: user name and password info filled in HTTP task don't take effect if reference page not filled
Download links
BitComet 1.09.exe
BitComet 1.09.zip
BitComet 1.09 plugin.exe
